Probleme Zabbix information under container
  • vince33
    • Mar 2022
    Hello community!
    After many months of testing, we finally put ZABBIX in production!
    I have a little problem with the "system information" Zabbix it does not go up ....
    The zabbix-server agent is OK and the other Host too !
    The installation is done under Rockylinux (Selinux deactivated) -> Docker
    Under Docker I don't know how to configure the file "zabbix.conf.php" (not possible under a container ??)
    PHP Code:
    docker run --name zabbix-server-mysql \
    t -e DB_SERVER_HOST="mysql-server" \
    e MYSQL_DATABASE="zabbix_XXXX" \
    e MYSQL_USER="zabbix_XXX" \
    e MYSQL_PASSWORD="XXXXX" \
    e MYSQL_ROOT_PASSWORD="XXXXX" \
    e ZBX_JAVAGATEWAY="zabbix-java-gateway" \
    link mysql-server:mysql \
    link zabbix-java-gateway:zabbix-java-gateway \
    p 10051:10051 \
    restart unless-stopped \
    d zabbix/zabbix-server-mysql
    Thanks in advance !
    Translated with www.DeepL.com/Translator (free version)
