Issue after Updating from 5.4.9 to 5.4.11
  • magio
    • Apr 2021
    Zabbix was working fine with SSL enabled and self-certificate.
    Then I decided to update the sever, following simple process via apt over debian.
    After the update , many buttons do not work , for example Import template button, Signout button, etc.
    If enabling debugging I get a lot of regarding default-src 'self' and PHP_ZBX_FULL_DATE_TIME not being defined
    Any hints on the root cause for this?
    Thanks in advance
  • tim.mooney
    • Dec 2012
    • 1436
    When you updated, did PHP get updated? If so, have you set date.timezone and other PHP settings that are important to Zabbix?
    • magio
      • Apr 2021
      Thanks tim.mooney for your help.
      In fact it was something different, the update modified the sites-available file for apache2 (my webserver)
      Commenting it and restarting apache , solved the issue
      #Header set Content-Security-Policy "default-src 'self';"
