zabbix monitoring on Oracle databases with ODBC template
  • frankjustme
    • Mar 2022
    First post. I wasnt able to search through the forum posts so excuse this if its already been discussed. I am using Zabbix appliance on Centos linux. I am attempting to monitor Oracle databases using the Oracle odbc template. I'm using the recipe shown here in this blog... If there is a better setup process for Zabbix to monitor Oracle please give me that URL.
    Agentless Oracle database monitoring with ODBC - Zabbix Blog
    I have gone through and tested odbc and know that to be working. I cant seem to get Zabbix to monitor Oracle databases though. Here are the errors I'm seeing in the zabbix system log...
    44196:20220319:195327.620 discovery rule "emcc:db.odbc.discovery[archivelog,,"Driver={$ORACLE.DRIVER};DBQ=//{HOST.CONN}:{$ORACLE.PORT}/{$ORACLE.SERVICE};"]" became not supported: Cannot connect to ODBC DSN: [SQL_ERROR]:[01000][0][[unixODBC][Driver Manager]Can't open lib '<Put path to oracle driver here>' : file not found]
    44197:20220319:195328.623 discovery rule "emcc:db.odbc.discovery[asm,,"Driver={$ORACLE.DRIVER};DBQ=//{HOST.CONN}:{$ORACLE.PORT}/{$ORACLE.SERVICE};"]" became not supported: Cannot connect to ODBC DSN: [SQL_ERROR]:[01000][0][[unixODBC][Driver Manager]Can't open lib '<Put path to oracle driver here>' : file not found]
    44196:20220319:195329.622 discovery rule "emcc:db.odbc.discovery[db_list,,"Driver={$ORACLE.DRIVER};DBQ=//{HOST.CONN}:{$ORACLE.PORT}/{$ORACLE.SERVICE};"]" became not supported: Cannot connect to ODBC DSN: [SQL_ERROR]:[01000][0][[unixODBC][Driver Manager]Can't open lib '<Put path to oracle driver here>' : file not found]
    44197:20220319:195330.625 discovery rule "emcc:db.odbc.discovery[pdb_list,,"Driver={$ORACLE.DRIVER};DBQ=//{HOST.CONN}:{$ORACLE.PORT}/{$ORACLE.SERVICE};"]" became not supported: Cannot connect to ODBC DSN: [SQL_ERROR]:[01000][0][[unixODBC][Driver Manager]Can't open lib '<Put path to oracle driver here>' : file not found]
    44196:20220319:195331.625 discovery rule "emcc:db.odbc.discovery[tbsname,,"Driver={$ORACLE.DRIVER};DBQ=//{HOST.CONN}:{$ORACLE.PORT}/{$ORACLE.SERVICE};"]" became not supported: Cannot connect to ODBC DSN: [SQL_ERROR]:[01000][0][[unixODBC][Driver Manager]Can't open lib '<Put path to oracle driver here>' : file not found]
    My /etc/odbcinst.ini has this
    [OracleODBC]
    Description = Oracle ODBC driver for Oracle 21
    Driver = /usr/lib/oracle/21/client64/lib/libsqora.so.21.1
    The odbc.ini has a entry that I found to be required for Zabbix to create the connection string. It points to the driver entry in /etc/odbcinst.ini
    [$ORACLE.DSN]
    Driver = OracleODBC
    It appears that when Zabbix attempts to connect it isnt seeing the /etc/odbcinst.ini and doesnt know where the library is. Can anyone help me on the setup process for Zabbix to monitor Oracle ?
    Thanks in advance
  • skywalker
    • Apr 2023
    I followed the same guide and I am also stuck at the say point. Did you resolve it?
    • Ranjith.Rokkam
      • Oct 2023
      • 14
      Hello All - Greetings!
      Could someone please assist me with the Oracle DR monitoring that is not working in Windows 2012 R2 Server? I need your assistance in resolving this problem.
      Regards,
      Ranjith R
      • markfree
        • Apr 2019
        • 875
        See if this question helps you.
