"Report unknown triggers"
  • aliennick
    • Aug 2015
    • 55
    Hello. Tell me please how can i avoid "Report unknown triggers" in my email? I set an action conditions as Type of calculation = And, trigger value = problem, group = windows servers, and in user settings "Not classified" is not set. But i still receive messages from hosts that not in "windows hosts" group with "Report unknown triggers" in audit action and with "Unknown(or Normal): some host status".
    help me please. tnx.
  • ingus.vilnis
    • Mar 2014
    • 908
    Configuration -> Actions -> select Event source "Internal" in top right dropdown
    There is an action to report unknown triggers. I did not really get if you are setting your conditions there or in actions for normal triggers in problem state.
    How are your internal actions configured?
    Best Regards,
    Ingus
    • aliennick
      • Aug 2015
      • 55
      thank you very much! this is it. my fail. i deactivates Report of not supported and unknown items.
      • Solarnow
        • Jan 2017
        I also have a similar problem. FileShare is one of the hosts being monitored by zabbix on my end but every morning at 6:00am, it sends the below message. It also applies to other hosts being monitored on the zabbix server.
        Any solution?
        Trigger: Fileshare has just been restarted
        Trigger status: PROBLEM
        Trigger severity: Information
        Trigger URL:
        Item values:
        1. System uptime (Fileshare:system.uptime): 19:05:43
        2. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
        3. *UNKNOWN* (*UNKNOWN*:*UNKNOWN*): *UNKNOWN*
        Original event ID: 11730
        Susan
        • batchenr
          • Sep 2016
          • 440
          Any solution?
          Trigger URL:
          Item values:
          Susan
          whats the value of 1 and 2 ?
          and are you sure its not really restarting ?
