Version 1.1.3 Segfault
  • ddrager
    • Aug 2006
    • 13
    Having problem with 1.1.3 Segfaulting. zabbix_serverd runs through a bunch of data, but quits after a second or less. Debug log shows this:
    008980:20061024:100330 ZABBIX server is up.
    008984:20061024:100330 Executing query:select distinct h.host from hosts h,items i where i.hostid=h.hostid and (
    h.status=0 or (h.status=0 and h.available=2 and h.disable_until<=1161698610)) and (i.key_='icmpping' or i.key_='
    icmppingsec') and i.type=3 and i.status=0 and h.useip=0
    008984:20061024:100330 In do_ping()
    008980:20061024:100330 One server process died. Shutting down...
    008980:20061024:100330 0. Killing PID=[8982]
    It then kills all remaining processes.
    Strace shows that a thread is segfaulting after using gettimeofday()
    8986  gettimeofday( <unfinished ...>
    8985  gettimeofday( <unfinished ...>
    8986  <... gettimeofday resumed> {1161698610, 508655}, NULL) = 0
    8985  <... gettimeofday resumed> {1161698610, 508669}, NULL) = 0
    8986  --- SIGSEGV (Segmentation fault) @ 0 (0) ---
    8985  --- SIGSEGV (Segmentation fault) @ 0 (0) ---
    8980  <... nanosleep resumed> 0xbfe3b9e4) = ? ERESTART_RESTARTBLOCK (To be restarted)
    8980  --- SIGCHLD (Child exited) @ 0 (0) ---
    8980  time(NULL)                        = 1161698610
    8980  open("/var/log/zabbix_server.log", O_RDWR|O_APPEND|O_CREAT, 0666) = 1
    8980  fstat64(1, {st_mode=S_IFREG|0664, st_size=148572, ...}) = 0
    8980  mmap2(NULL, 4096, PROT_READ|PROT_WRITE, MAP_PRIVATE|MAP_ANONYMOUS, -1, 0) = 0xb7ff0000
    8980  write(1, "008980:20061024:100330 One serve"..., 65) = 65
    Any thoughts?
    System Info:
    CentOS 4.4
    Kernel: 2.6.9-34.0.2.ELsmp
    gcc version 3.4.6 20060404 (Red Hat 3.4.6-3)
    net-snmp version 5.3.1
  • ddrager
    • Aug 2006
    • 13
    This seems silly, but this fixed itself after I killed zabbix_agentd. I guess running the agent on the old version, and serverd on the new version, was causing serverd to segfault. It's working great now!
