New installation problems with NGINX
  • yerun
    • Oct 2020
    Hello all,
    I tried several times to do a clean install of Zabbix 6 LTS on Ubuntu 20 LTS, but I can't get it working. Following the instructions:
    Zabbix is being downloaded over 4 000 000 times every year for a reason. Download and install Zabbix for free and try it yourself!
    I always end up with a default NGINX page ('Welcome to NGINX'). Found a Youtube video where it says to add '/zabbix' to the URL but that doesn't work either. Anyone got it working with NGINX and how? I might have to go for Apache instead. Thanks.
  • simonuk1
    • Mar 2009
    • 66
    Just had the same issue.
    If you got ,/etc/nginx/enabled-sites and delete the default link in there it will start working once you restart nginx service. Reason is the default nginx config is enabled and is listening on same port 80.
    • yerun
      • Oct 2020
      Thanks Simon, unfortunately it didn't work. I deleted the default link that is there. Even restarted the server but I still get the default NGINX page.
      Might try Apache some time later, after 4 attempts with NGINX i'm a bit fed up with up.
      • incama
        • Jan 2015
        • 66
        In some distro's when using Nginx, there is also a default file in /etc/nginx/conf.d directory. Just delete this file.
        • yerun
          yerun commented
          I did and even restarted the server. Still get the default NGINX welcome page. Thanks anyway.
      • yerun
        • Oct 2020
        I decided to start all over again using a tutorial from DigitalOcean, skipping step 4. Still no success, although everything seems to check out. All services running. Only thing is I didn't set up an external domain name. I edited the nginx.conf to listen on port 80 and used a local servername (e.g. myserver.mydomain.local).
        And again a default NGINX welcome page. I have version 1.20.2.
        Also I noticed there is no 'sites-available' folder under /etc/nginx which I had expected to be there.
        Did anyone ever get a successful Zabbix install with NGINX I wonder?
        • simonbakker
          • Apr 2022
          It doesnt matter that much.... but what is your nginx conf right now?
          • yerun
            yerun commented
            Here it is, located at /etc/zabbix:
            server {
            listen 80;
            server_name olympia;
            root /usr/share/zabbix;
            index index.php;
            location = /favicon.ico {
            log_not_found off;
            location / {
            try_files $uri $uri/ =404;
            location /assets {
            access_log off;
            expires 10d;
            location ~ /\.ht {
            deny all;
            location ~ /(api\/|conf[^\.]|include|locale) {
            deny all;
            return 404;
            location /vendor {
            deny all;
            return 404;
            location ~ [^/]\.php(/|$) {
            fastcgi_pass unix:/var/run/php/zabbix.sock;
            fastcgi_split_path_info ^(.+\.php)(/.+)$;
            fastcgi_index index.php;
            fastcgi_param DOCUMENT_ROOT /usr/share/zabbix;
            fastcgi_param SCRIPT_FILENAME /usr/share/zabbix$fastcgi_script_name;
            fastcgi_param PATH_TRANSLATED /usr/share/zabbix$fastcgi_script_name;
            include fastcgi_params;
            fastcgi_param QUERY_STRING $query_string;
            fastcgi_param REQUEST_METHOD $request_method;
            fastcgi_param CONTENT_TYPE $content_type;
            fastcgi_param CONTENT_LENGTH $content_length;
            fastcgi_intercept_errors on;
            fastcgi_ignore_client_abort off;
            fastcgi_connect_timeout 60;
            fastcgi_send_timeout 180;
            fastcgi_read_timeout 180;
            fastcgi_buffer_size 128k;
            fastcgi_buffers 4 256k;
            fastcgi_busy_buffers_size 256k;
            fastcgi_temp_file_write_size 256k;
        • vicxcl
          • Mar 2022
          Check that /etc/nginx/nginx.conf has below code:
          include /etc/nginx/sites-enabled/*
          Create the sites-enabled folder
          And link the nginx.conf from the /etc/zabbix folder under sites-enabled folder
          ln -s /etc/zabbix/nginx.conf /etc/nginx/sites-enabled/zabbix.conf
          Restart nginx to ensure all files are loaded.
