map link label
  • leandroecomp
    • Jan 2022
    map link label
    Hey guys
    I'm monitoring a switch and I want to use traffic from an interface in the map.
    I'm using with syntax {SWITCH_01:net.if.in[ifInOctets.119].last(0)} but it is not working.
    Any idea?
  • Answer selected by leandroecomp at 29-03-2022, 14:03.
    Hamardaban
    • May 2019
    • 2714
    Carefully read the documentation for YOUR version. The syntax of the expression is different for different versions.
    For latest - https://www.zabbix.com/documentation...nking-elements
    • Hamardaban
      • May 2019
      • 2714
      • leandroecomp
        • Jan 2022
        Hi Hamardaban
        In fact, the settings have changed depending on the version. I solved the problem by changing the hostname which is in the configuration. It doesn't work with the IP of the interface.
        Something like:
        {?last(/SWITCH_01/net.if.in[ifInOctets.119])}
        {?last(/SWITCH_01/net.if.out[ifOutOctets.119])}
        It works! Thanks.
