Zabbix Dashboard issue
  • KitCB
    • Jan 2016
    I have been using Zabbix for several years to monitor 30+ resources with no issues and am quite dependent on it.
    Recently, I have discovered that the Zabbix Dashboard is no longer reporting problems accurately. Five times over the last month, (since upgrading to 2.4.7) I have been notified by a user that one or more servers were unavailable - but the Zabbix Dashboard reports no problems. However, if I switch the view to host configurations, and list the servers then I can see the red Icon showing that the problem server is indeed in a trouble state. However switching back to the Dashboard (and refreshing the view etc.) still shows no problems. Other than upgrading to new versions as released over the last 3 or 4 years, I have made no configuration changes to the dashboard, events, triggers etc.
    Of course, when I discover the problem, there is very little time to troubleshoot. A post problem review of the logs does not readily reveal any clues. Since Zabbix has worked so well for so long, I haven't spent any real time troubleshooting problems so I am feeling rather noobie digging into things. Any suggestions where I should look to figure out what it going on?
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello and welcome to Zabbix forums!
    As the first step to troubleshoot this I would recommend you to check overall performance of your Zabbix server. A good starting point would be this article: https://www.zabbix.com/forum/showthread.php?t=47781
    Also check that you have latest template for internal monitoring (especially if you did upgrade from previous versions, like 2.0). Templates can be downloaded from here: https://share.zabbix.com/official-te.../zabbix-server
    But be careful with updating the templates if you have created some customizations in your current ones.
    Best Regards,
    Ingus
    • KitCB
      • Jan 2016
      Thanks - the links enabled me to figure out that I needed to move a few pooler values above the defaults which in turn solved the problems.
      • amoud
        • Jun 2015
        it's good
        • RomsMaklaet
          • Aug 2015
          your information really useful for me.
          เกมส์บาคาร่า
