Zabbix 6 New installation: No data with mysql agent template
  • kefler
    • Apr 2022
    I installed new Zabbix 6.0.3 LTS on Debian 11. Everything works great, but I have problem with monitoring host with MariaDB 10.6.7 (Debian 11) using dedicated template. On Zabbix Server I configured new host to monitoring by "MySQL by Zabbix agent" template to monitoring. According to https://www.zabbix.com/integrations/mysql:
    1. On mariadb host I created /etc/zabbix/zabbix_agentd.d/template_db_mysql.conf with:
    #template_db_mysql.conf created by Zabbix for "Template DB MySQL" and Zabbix 4.2
    #For OS Linux: You need create .my.cnf in zabbix-agent home directory (/var/lib/zabbix by default)
    #For OS Windows: You need add PATH to mysql and mysqladmin and create my.cnf in %WINDIR%\my.cnf,C:\my.cnf,BASEDIR\my.cnf https://dev.mysql.com/doc/refman/5.7/en/option-files.html
    #The file must have three strings:
    #[client]
    #user='zbx_monitor'
    #password='<password>'
    UserParameter=mysql.ping[*], mysqladmin -h"$1" -P"$2" ping
    UserParameter=mysql.get_status_variables[*], mysql -h"$1" -P"$2" -sNX -e "show global status"
    UserParameter=mysql.version[*], mysqladmin -s -h"$1" -P"$2" version
    UserParameter=mysql.db.discovery[*], mysql -h"$1" -P"$2" -sN -e "show databases"
    UserParameter=mysql.dbsize[*], mysql -h"$1" -P"$2" -sN -e "SELECT COALESCE(SUM(DATA_LENGTH + INDEX_LENGTH),0) FROM INFORMATION_SCHEMA.TABLES WHERE TABLE_SCHEMA='$3'"
    UserParameter=mysql.replication.discovery[*], mysql -h"$1" -P"$2" -sNX -e "show slave status"
    UserParameter=mysql.slave_status[*], mysql -h"$1" -P"$2" -sNX -e "show slave status"
    2. Created a MySQL user for monitoring:
    CREATE USER 'zbx_monitor'@'%' IDENTIFIED BY 'mypassword'; GRANT REPLICATION CLIENT,PROCESS,SHOW DATABASES,SHOW VIEW ON *.* TO 'zbx_monitor'@'%';
    3. On mariadb host I created /var/lib/zabbix/.my.cnf:
    [client]
    user='zbx_monitor'
    password='mypassword'
    4. Restart zabbix-agent by:
    systemctl restart zabbix-agent
    Unfortunatelly, I cannot see any data in Monitoring → Latest data for monitored host. There is only an exclamation mark with message:
    Preprocessing failed for: WARNING: Forcing protocol to TCP due to option specification. Please explicitly state intended ...
    1. Failed: cannot extract XML value with xpath "/resultset/row[field/text()='Connection_errors_tcpwrap']/field[@name='Value']/text()": cannot parse xml value: Start tag expected, '<' not found
    In zabbix server logs (/var/log/zabbix/zabbix_server.log) I found:
    noname.xml:1: parser error : Start tag expected, '<' not found
    Zabbix user on mariadb host has HOME variable at /var/lib/zabbix:
    cat /etc/passwd
    zabbix:x:108:116::/var/lib/zabbix/:/usr/sbin/nologin
    Any advice?
  • LarsV
    • Jun 2022
    I have the same problem as descriped above.
    I to have a Debian 11 on client/ agent and server.
    But running Zabbix server 5.4.12
    My MariaDB version is 10.6.8.
    This is working finde on same server with data from other agents.
    And the main difference i can find is that the clients/ agents where it works is running MariaDB v. 10.5.15.
    • Markku
      • Sep 2018
      • 1784
      What happens if you try to remove that error message by specifying the protocol in the mysql/mysqladmin commands? --protocol=tcp
      Markku
      • LarsV
        • Jun 2022
        Markku
        Then it works for me.
        Thanks for pushing me in the right direction.
        Now to find out why.
        • cyztalzboyz
          • Mar 2022
          How do you fix? please detail for help
