net.tcp.port fails if target is down
  • RobertS
    • Aug 2006
    • 57
    I want to monitor port 3389 on a server with [net.tcp.port[10.20.1.103,3389]]. As long as the server is up the results are as expected, but when the server goes down the status is not updated anymore an keeps as OK ("1" on 1.1.3; "0" on previous) which is not exactly correct on a shutdown server. Zabbix Server is 1.1.2, Agent is Windows 1.1.2
    zabbix_server.log
    009243:20061025:111821 Getting value of [net.tcp.port[10.20.1.103,3389]] from host [work] failed
    009243:20061025:111821 The value is not stored in database.
    Thanks for help,
    Robert
  • RobertS
    • Aug 2006
    • 57
    I now trigger on nodata() also.
    eg.
    ({mypc:net.tcp.port[2.1.17.5,5019].last(0)}#1)|({mypc:net.tcp.port[2.1.17.5,5019].nodata(120)}=1)
    • cadbury
      • Apr 2005
      • 77
      to monitor a host status, I always set an icmpping as the condition to other triggers.
      when the icmpping is false, no need to care about other values.
      • RobertS
        • Aug 2006
        • 57
        The problem is that the port I want to monitor is on an external server which is only reachable from one host in my network. It's a Windows host with a VPN conntection to the external server doing the net.tcp.port. So I have to monitor if my host can reach the external server and if the port on the external server is reachable.
        As I understand icmpping is always send from the Zabbix Server an there is no (built in) way to check if a Zabbix Agent can ping a single server.
        • cadbury
          • Apr 2005
          • 77
          ok I see the problem
          if your solution works, all right
          you can also set a simple script on the windows server that will ping what you want, but you may not need it now
          • bashman
            • Dec 2009
            • 432
            Problem still persists on Zabbix agent (win) v1.8.4:
            978 Hosts / 16.901 Items / 8.703 Triggers / 44 usr / 90,59 nvps / v1.8.15
