No email sent on trig when frontend messaging is enabled
  • tsoc
    • Jan 2016
    People Hi !
    I've just discovered the Zabbix frontend messaging option, very nice way to be alerted in realtime.
    However, when Frontend messaging option is enable, the emails that I usually received on a trig are not sent.
    Could someone confirm that frontend messaging disable email sending ?
    Regards.
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello and welcome to Zabbix forums!
    Can you double check if you are receiving emails when frontend messaging is disabled?
    They are not connected so the reason could be something else. Can you check Configuration -> Actions if the action is not disabled unintentionally?
    Best Regards,
    Ingus
