Libevent-2.1.8 required while upgrading to proxy-mysql-6.0.0, Ubuntu 20.04 LTS
  • vkanta
    • Nov 2019
    Dear Forum,
    I have upgraded our Zabbix instance withour issues from 5.4 to 6.0 LTS. When i try to upgrade our proxy instance as well to 6.0.0 so that both versions are the same as required, i am unable to perform the instalation using the apt installer
    i get the error that depependencies are missing;
    libevent-2.1.6 (2.1.8.. ) but is not installable
    libmysqlclient20 but is not installable
    libsnmp30 , "" ""
    Has this senario been somehow troubleshooted ?
    any help will be appriciated
    with kind regards
    BK
  • Atsushi
    • Aug 2013
    • 2028
    I think you haven't set up the required Ubuntu repository. Did you install Ubuntu offline and remove the local DVD media settings from source.list? Check the contents of /etc/apt/sources.list. Perhaps the focal main repository settings are commented out or invalid access destinations are set.
