Is Zabbix repo broken ?
  • TR-1892
    • Apr 2022
    I Tried to update zabbix 5.0.17 with command "dnf update"
    last metadata expiration check: 0:12:14 ago on Fri 08 Apr 2022 06:35:40 AM EEST.
    Module yaml error: Unexpected key in data: static_context [line 9 col 3]
    Error:
    Problem 1: cannot install the best update candidate for package zabbix-web-5.0.17-1.el8.noarch
    - nothing provides js-jquery >= 3.6.0 needed by zabbix-web-6.0.2-1.module_el8+14182+e1fc92db.noarch
    Problem 2: package zabbix-web-mysql-6.0.2-1.module_el8+14182+e1fc92db.noarch requires zabbix-web = 6.0.2-1.module_el8+14182+e1fc92db, but none of the providers can be installed
    - cannot install the best update candidate for package zabbix-web-mysql-5.0.17-1.el8.noarch
    (try to add '--skip-broken' to skip uninstallable packages or '--nobest' to use not only best candidate packages)
  • TR-1892
    • Apr 2022
    Problem was in epel-modular repo not zabbix repo.
    • bruxef
      • May 2022
      try:
      dnf upgrade libmodulemd
      after upgrade, try:
      dnf update
