Sorry, i am not a DB guru here. Therefore, i very much rely on the notes provided by Zabbix official documentation for upgrade.
When reviewing and testing the "Database upgrade to primary keys" procedures, i got the non-existing function error for the step below:
select set_integer_now_func('history_uint', 'zbx_ts_unix_now', true);
By querying the original database, i don't find the 'zbx_ts_unix_now' function. Then, i set up another postgresqlDB after running Zabbix6 'server.sql.gz' and 'timescaledb.sql' scripts, i still don't see the function 'zbx_ts_unix_now' . May i ask if i miss something?
Then, i found a related bug has been filed under ZBX-18136. It was closed with 'Won't Do' status. May i ask then if 'set_integer_now_func()' is required for the upgrade primary-key notes?
Any help will be appreciated!
