Unsupported item key using zabbix agent with "Postgresql by zabbix agent" template
  • patekfilip
    • Apr 2022
    Hi everyone !
    I have been reading on this topic throughout this Forum and also other internet sites, but I am still not able to find what is wrong with my installation/config.
    I am using Zabbix LTS 6 on ubuntu 20.04. I set up a sample host with postgresql 14 database. I linked the "Posgresql by zabbix agent" and "Linux by zabbix agent" templates to the host. I have no problem with Linux template, but postgres template does not work.
    All pgsql.* item keys show as unsupported when looking in the zabbix agent log (debug mode does not give any additional info) or when running zabbix_get. Connection to the database seems to be set up properly: checked firewall, pg_hba.conf, db user, etc...
    When I check the zabbix server database, I can see that the pgsql item keys can be found in the items table.
    If anyone has similar experience, or knows the solution, I would really appreciate your help, I have been stuck for two days on this topic.
    Best Regards,
    Attila Cseke
  • abhitrip14
    • Sep 2024
    I am also facing same problem and tried multiple things but no luck.
    Abhishek
      • 4996
      Using zabbix agent instead of zabbix_agent2?
