Slack Bot functionality
  • Cortela
    • Apr 2022
    Hello, i have a Slack bot and if get problem then send to SLack notify... after time problem is resolved, where send to Slack notify message with "Resolved" but before message with "Problem" bot is removing.
    Can I set the Slack boot so that it does not clear the previous message that the problem occurred? How?
    thx
  • Atsushi
    • Aug 2013
    • 2028
    If you are using Zabbix standard Slack media settings, try changing slack_mode from alarm to event.
    https://git.zabbix.com/projects/ZBX/...es/media/slack
