docker proxy serverport
  • ramoneastral
    • Feb 2017
    • 33
    i have server and proxy running in docker on synology since 4 dot something.
    latest stable was the zabbix docker image of 5.4.latest .
    i tried to upgrade to 6 today.
    did so with the server image of ubuntu.6.latest is not an issue.
    5.4 proxy reports into server and delivering data of clients.
    now i tried to do the same with 6.latest proxy-sqlite3 .
    it will not pick up the serverport env ???
    at startup you will see something like this
    Updating '/etc/zabbix/zabbix_proxy.conf' parameter "ServerPort": '31779'...updated
    but then it will complain that serverIP:10051 is not reachable ??
    it seem to not pick up the config for the serverport ....
    starting the "old " image of 5.4.latest image will just start to work fine .
    any ideas why ?
  • ramoneastral
    • Feb 2017
    • 33
    not on docker but on a "fat" debian11 install , systemctl status smiles at me with this :
    zabbix_proxy[749762]: zabbix_proxy [749762]: Warning: ServerPort parameter is deprecated, please specify port in Server parameter separated by ':' instead
    could that be the reason for the docker issue ?
