Can't close problem on ZABBIX server 6.0.2
  • KornZAB
    • Apr 2022
    Hi ALL
    Sorry please, I am new for ZABBIX tool monitoring. Please help advise to me for close problem on ZABBIX server 6.0.2. I try many time and still can't manual close problem.
    Thank you sir.
  • max.
    • Apr 2022
    • 40
    Hello KornZAB,
    Make sure you have enabled the "allow manual close" check box in the trigger configuration.
    Regards
    • KornZAB
      • Apr 2022
      Thank you so much max. Now , i can close problem and issue was fixed.
      • godbucket
        • May 2025
        This is hilarious, because the "allow manual close" checkbox itself won't allow it to be checked, lol wow
        • z0nk
          • Oct 2024
          • 45
          Any idea how solve it? Same there with superadmin.
            • 5004
            Some discovered trigger? You should lmodify prototype then...
