Calculated items in Zabbix 6 does't work properly
  • Ultrasonic
    • Sep 2015
    Situation:
    There is not possible to do simple result of subtraction in calculated item - for example:
    I have simple file somefile.txt that contains only static value "20", then I do calculation in calculated item:
    last(/Zabbix server/logrt[/somefile.txt])-10-2
    result: 10, but should be: 20-10-2=8
    another test:
    last(/Zabbix server/logrt[/somefile.txt])-10-2-1-1-1
    result: 10, but should be: 5
    but this works properly:
    last(/Zabbix server/logrt[/somefile.txt])-10+2
    result: 12, it's ok: 20-10+2=12
    another test:
    last(/Zabbix server/logrt[/somefile.txt])-10+2+1+1+1
    result: 15, it's ok: 20-10+2+1+1+1=15
    So, problem is only in substraction. In Zabbix 5.0.x all works fine, but not n Zabbix 6.x.x (my version is 6.0.3)
    Anyone can confirm that?
