Zabbix mySQL Linked Server with SQL
  • wpagane
    • Apr 2021
    • 31
    Hello Team,
    I have the following environment.
    • Zabbix 5.2 + mySQL
    • 8 CPU COREs
    • 16 GB RAM
    • CentOS 8
    I was able to created a Linked Server for DB zabbix (mySQL) with a SQL Server. Its OK, I'm able to access DB as well and run a simple SELECT.
    PROBLEM:
    • When I try to run a more complex SELECT query through SQL Server Management Studio, it takes too long to run and/or it gets a failure, for exemple:
    SELECT T2.*
    ,(SELECT TOP 1 value FROM OPENQUERY (ZABBIX, 'SELECT * FROM history' ) WHERE itemid = t2.itemid ORDER BY clock DESC) [Values1]
    FROM
    (SELECT t1.hostid, itemid
    ,(SELECT TOP 1 NAME FROM OPENQUERY (ZABBIX, 'SELECT * FROM hosts') where t1.hostid = hostid) HOSTNAME
    ,t1.key_ Item
    ,(SELECT TOP 10000 value FROM OPENQUERY (ZABBIX, 'SELECT * FROM history_text' ) WHERE itemid = t1.itemid ORDER BY clock DESC) [Values]
    FROM
    (SELECT *
    FROM OPENQUERY
    ZABBIX,
    'SELECT * FROM items'
    WHERE key_ IN ('system.sw.packages', 'system.cpu.util[,idle]') and hostid in ('10084'))T1 ) T2
    My currently /etc/my.cnf configuration has the following information. Should it be changed to something better? Any hints? I have around 80 hosts. Thank you very much!!!
