Zabbix 5.0 - Error 404 Not Found on CentOS 7
  • tpgala
    • Apr 2022
    Trying to install Zabbix 5.0 on CentOS 7.
    Getting Error 404 Not Found. The requested URL /zabbix was not found on this server.
    zabbix server log:
    27857:20220425:122755.187 Starting Zabbix Server. Zabbix 5.0.22 (revision 90ee9e33d3).
    27857:20220425:122755.187 ****** Enabled features ******
    27857:20220425:122755.187 SNMP monitoring: YES
    27857:20220425:122755.187 IPMI monitoring: YES
    27857:20220425:122755.187 Web monitoring: YES
    27857:20220425:122755.187 VMware monitoring: YES
    27857:20220425:122755.187 SMTP authentication: YES
    27857:20220425:122755.187 ODBC: YES
    27857:20220425:122755.187 SSH support: YES
    27857:20220425:122755.187 IPv6 support: YES
    27857:20220425:122755.187 TLS support: YES
    27857:20220425:122755.187 ******************************
    27857:20220425:122755.187 using configuration file: /etc/zabbix/zabbix_server.conf
    27857:20220425:122755.188 cannot set MySQL character set to "utf8"
    27857:20220425:122755.189 cannot set MySQL character set to "utf8"
    27857:20220425:122755.189 current database version (mandatory/optional): 05000000/05000005
    27857:20220425:122755.189 required mandatory version: 05000000
    27857:20220425:122755.189 Zabbix supports only "utf8,utf8mb3" character set(s). Database "zabbix_db" has default character set "utf8mb4"
    27857:20220425:122755.189 Zabbix supports only "utf8_bin,utf8mb3_bin" collation(s). Database "zabbix_db" has default collation "utf8mb4_bin"
    27857:20220425:122755.192 cannot set MySQL character set to "utf8"
    Can anyone help me to solve this issue?
  • Atsushi
    • Aug 2013
    • 2028
    Did you install zabbix-web package and related packages? Please show me the list of currently installed zabbix related packages. And, please tell us what version of PHP you are using, where you got it, and what you are using for your web server.
    And, please make sure that the character set of the database for Zabbix is utf8.
    • tpgala
      • Apr 2022
      zabbix-agent.x86_64 5.0.22-1.el7 zabbix
      zabbix-apache-conf-scl.noarch 5.0.22-1.el7 zabbix-frontend
      zabbix-release.noarch 5.0-1.el7 installed
      zabbix-server-mysql.x86_64 5.0.22-1.el7 zabbix
      zabbix-web.noarch 5.0.22-1.el7 zabbix-frontend
      zabbix-web-deps-scl.noarch 5.0.22-1.el7 zabbix-frontend
      zabbix-web-mysql-scl.noarch 5.0.22-1.el7 zabbix-frontend
      php.x86_64 7.3.33-1.el7.remi
      • Atsushi
        • Aug 2013
        • 2028
        It doesn't work with a combination of packages that require SCL packages and remi's PHP packages. Either select SCL or remi.
