Hello everyone
I've been using Zabbix for years, an d I ad a special alert system that should be processed in bash. I had no problem with that system in versions 3 to 5.
Since in version 6.0 I had to create script for alerts, I faced this problem. and here is my problem.
This is my action that works in old versions:
specially this part:
what I did was to change the format to the new version as below
Or
Or whatever came to my mind, but it didn't work
The reason I did this that when an alert is triggered an special application should get connected to our radius server and make some changes.
Is there any way that make it work?
Thanks in advance
bash /usr/lib/zabbix/alertscripts/alert "{EVENT.NAME}","Date : {DATE}","address : {HOST.IP}","Name : {HOST.NAME}","Old value : {{HOST.HOST}:{ITEM.KEY}.avg(10m,3m)}","current value: {ITEM.VALUE}","changed value : http://{$ZABBIX_IP}/zabbix/history.php?action=showgraph#itemids[]={ITEM.ID}","changed device : {TRIGGER.URL}"
"Old value : avg(/{HOST.HOST}/{ITEM.KEY},3m:now-10m)"
"Old value : {avg(/{HOST.HOST}/{ITEM.KEY},3m:now-10m)}"
Thanks in advance
