ZABBIX 2.4 - Unable to create Web Monitor Scenario - Incorrect value for Name
  • brian.dougherty
    • Jan 2016
    I am attempted to create a web monitoring scenario and I am unable to save because of the following error -
    preg_match(): Compilation failed: range out of order in character class at offset 11 [popup_httpstep.php:55 → check_fields() → check_field() → calc_exp() → calc_exp2() → eval() → preg_match() in /mount/httpd-2.2.31/htdocs/zabbix/include/validate.inc.php(105) : eval()'d code:1]
    Incorrect value "TEST" for "Name" field.
    I have tried multiple different names in the Name feild with the same result.
    RHEL 6 - apache httpd - PHP 5.3.3 - mysql 5.6.28
    Thanks!
  • ingus.vilnis
    • Mar 2014
    • 908
    Hello and welcome to Zabbix forums!
    Looks like your issue is ready to be developed.
    Best Regards,
    Ingus
