I am having an issue where the Mounted Filesystem Discovery is finding ALL of my NTFS formatted volumes, and NONE of my ReFS formatted ones. I have searched this forum and the internet in general via Google, but have not seen anyone talking about this issue. My apologies in advance if it has been discussed elsewhere that I did not find.
I have three Zabbix server installs, all on CentOS 7 minimal, fully updated, with Zabbix Server version 2.4.7. I am monitoring three Windows Server 2012 R2 installations, two physical and one virtual, all fully updated, and with agent version 2.4.4.52334 (per the version builtin to zabbix_agentd.exe).
Each Windows server is created with the stock "Template OS Windows", with the only changes made to the triggers (change free disk space warning from 20% to 15%).
Here is a summary of what volumes are present on each server, and whether they are found by the Mounted Filesystem Discovery.
Server#1: (physical)
C: - physical, NTFS, detected
F: - physical, NTFS, detected
G: - Storage Spaces, NTFS, detected
M: - Storage Spaces, ReFS, not detected
O: - Storage Spaces, ReFS, not detected
Z: - Storage Spaces, ReFS, not detected
Server#2: (VM)
C: - Microsoft Virtual Disk, NTFS, detected
X: - Microsoft Virtual Disk, ReFS, not detected
Y: - Microsoft Virtual Disk, ReFS, not detected
Server#3: (physical)
F: - Storage Spaces, NTFS, detected
X: - Storage Spaces, NTFS, detected
Y: - Storage Spaces, ReFS, not detected
As I hope you can see, it does not appear to matter what underlying type of drive it is, any ReFS volume is not detected, and any NTFS volume is. Please let me know if there is anything I should do or check before filing a bug report for this issue.
Server#2: (VM)
