MSSQL: Number of DataBases
  • wpagane
    • Apr 2021
    • 31
    Hello Team,
    Zabbix Version: 5.2
    I was able to install ODBC and I'm now able to monitor my Servers Databases using Template "MSSQL by ODBC" as well!
    However, there is a need to know the "Number of Databases" which have been discovered.
    I found out an item called "MSSQL: Number users connected" --> That's OK. But now, I need to know the "Number of Databases" for that specific Server. I searched around and I didn't find any ITEM which could output this information. Does anybody here could please provide some hints of how could I get this number?
    Thanks a lot in advanced!
  • Hamardaban
    • May 2019
    • 2714
    SELECT count(1) FROM sys.databases
    • wpagane
      wpagane commented
      Hamardaban - You're the man! Thanks a lot! It works and now I'm displaying this info in a Grafana's dashboard.
      I don't want to bother you anymore, BUT, if maybe you also have any hints to get the Number of IIS Applications monitored (Sites and/or Application Pools) it would be nice!!!
      I'm already using Template "IIS by Zabbix agent" discovering IIS Pools as well, but getting trouble to make a "count", for example: "Count of IIS Sites", "Count of IIS Application Pools".
  • Rachelfoster
    • Jul 2022
    • 11
    I want to know more that How do I count the number of databases in SQL Server? How many databases are there in SQL Server? Kohl's Feedback Survey
