Error "Zabbix agent is not available (or nodata for 30m). I confirmed that 10050\tcp is open on each of the linux servers running the agent. Also confirmed that the *.conf file has both passive check "Server=10.100.x.x" (Zabbix Server), active check "ServerActive=10.100.x.x" settings, and "Hostname=Agent2onthisServer".
Data is being collected by the agent and relayed to the Zabbix Server server yet the zabbix status remains (Unavailable).
tail -f of zabbix_agent2.log
Zabbix server logs have the following errors:
Each of these are the linux servers having issues with the agent.
Any assistance with this would be greatly appreciated.
Im available for call or discussion 9-5p PST
2022/05/12 15:46:10.851763 using plugin 'VFSDev' (built-in) providing following interfaces: exporter, collector
2022/05/12 15:46:10.851768 using plugin 'VFSDir' (built-in) providing following interfaces: exporter
2022/05/12 15:46:10.851774 using plugin 'VfsFs' (built-in) providing following interfaces: exporter
2022/05/12 15:46:10.851779 using plugin 'WebCertificate' (built-in) providing following interfaces: exporter, configurator
2022/05/12 15:46:10.851783 using plugin 'WebPage' (built-in) providing following interfaces: exporter, configurator
2022/05/12 15:46:10.851787 using plugin 'ZabbixAsync' (built-in) providing following interfaces: exporter
2022/05/12 15:46:10.851793 using plugin 'ZabbixStats' (built-in) providing following interfaces: exporter, configurator
2022/05/12 15:46:10.851796 lowering the plugin ZabbixSync capacity to 1 as the configured capacity 100 exceeds limits
2022/05/12 15:46:10.851800 using plugin 'ZabbixSync' (built-in) providing following interfaces: exporter
2022/05/12 15:46:10.851892 Zabbix Agent2 hostname: [Server.domain]
403124:20220512:165931.411 cannot link template(s) "Linux by Zabbix agent" to host "ServerZERO": conflicting item key "agent.hostname" found
403124:20220512:170044.653 cannot link template(s) "Linux by Zabbix agent" to host "ServerTWO": conflicting item key "agent.hostname" found
403124:20220512:170054.682 cannot link template(s) "Linux by Zabbix agent" to host "ServerTHREE": conflicting item key "agent.hostname" found
403124:20220512:170805.867 cannot link template(s) "Linux by Zabbix agent" to host "ServerTestTERRANE": conflicting item key "agent.hostname" found
