SNMP System Uptime - Format Data
  • gmatteson
    • Oct 2006
    I am able to pull the system uptime in TimeTicks and it is formated in Zabbix as a number e.g. 250806440. Is there a way for me to display this in days, hours, seconds etc? Thanks,
    - Gabe
  • dantheman
    • May 2006
    • 209
    Use a custom multiplier of .01 and s for the Units and I believe the "type" has to be Numeric(float) for that to work properly.
    • gmatteson
      • Oct 2006
      Thank You
      Thank you, that works great! Is there any information out there regarding variables that you can put into the units and how to use the custom multiplier?
      • marjob
        • Jun 2013
        set units to "uptime"
