Problème port
  • Romain31
    • May 2022
    Problème port
    I have to use several hosts behind the same public IP address. Since I upgraded to version 6 of zabbix server, I can no longer use any port other than 10050 or 10051
    I thought there was a nat error on my router but I turned on my old zabbix server and there it works with any port.
    I captured the ip frames. The server does not send requests if I enter a port other than 10050 or 10051.
    If you had the problem and/or know how to fix it, thank you.++
    Romain
  • Markku
    • Sep 2018
    • 1784
    Sounds like a problem in the new server platform. Does the new server have some specific security features enabled, like SELinux or very strict firewall rules?
    Markku
    • Romain31
      • May 2022
      I just switched SELINUX to permissive mode and presto, everything works, thank you very much.
      Romain
