Error Importing Template for Sophos XG 18
  • kola
    • Feb 2020
    • 20
    I have a couple of Sophos firewalls i monitor in Zabbix via SNMP however after moving and setting up version 6.0 I could not monitor the firewalls anymore. I found a template that should work on GitHub however when i try to import it into Zabbix i get the following error
    Zabbix version is 6.0.4 , not sure if anybody else has run into this issue and if there is a possible resolution. The template was downloaded from https://github.com/zabbix/community-...ion_18.0.x/6.0
  • Markku
    • Sep 2018
    • 1784
    Did you use the Raw button before saving the yaml file from GitHub? I mean, it looks like you have samed some html page instead of the raw yaml file.
    Markku
    • kola
      • Feb 2020
      • 20
      Markku
      Thanks for the response. I do see the raw button but what i did initially was to right click on the file and save as .yaml extension. When i click on the RAW button it displays the file contents in a new browser window. Should i copy the code, paste in a text editor and save as Instead?
      • kola
        • Feb 2020
        • 20
        I got it to work by copying and pasting into notepad++ and saving as .yaml. This worked and i was able to import into Zabbix unfortunately it seems the template does not work with my model of Sophos XGS3100 all the items in he template show up as unsupported when applied to the firewall in Zabbix.
