How can monitor EMC devices by zabbix6
  • bab
    • Aug 2020
    • 194
    I am using this doc for monitor EMC unity
    Python script for monitoring EMC Unity strages. Contribute to aklyuk/zabbix-emc-unity development by creating an account on GitHub.
    Unfortunately when I run it as follow it returns 1 and not return 0
    [root@z6 externalscripts]# ./unity_get_state.py --api_ip=172.2.2.2 --api_port=443 --api_user="monitor" --api_password="pass@123" --storage_name=bakunity --discovery
    1
    Also it shows in the unity_state.log
    2022-05-21 19:29:51,502 - unity_logger - INFO - Connection established
    2022-05-21 19:29:54,683 - unity_logger - INFO - Logout successful
    2022-05-21 19:32:51,118 - unity_logger - INFO - Connection established
    2022-05-21 19:32:54,320 - unity_logger - INFO - Logout successful
    2022-05-21 19:35:34,116 - unity_logger - INFO - Connection established
    2022-05-21 19:35:37,298 - unity_logger - INFO - Logout successful
    2022-05-21 19:35:51,112 - unity_logger - INFO - Connection established
    2022-05-21 19:35:54,306 - unity_logger - INFO - Logout successful
    2022-05-21 19:38:51,165 - unity_logger - INFO - Connection established
    2022-05-21 19:38:54,381 - unity_logger - INFO - Logout successful
    Why it cannot return 0 ? What is the problem
    I have defined storage_name=bakunity in zabbix . Also my zabbix-server version is 6
  • Markku
    • Sep 2018
    • 1784
    1 means that send_data_to_zabbix() (https://github.com/aklyuk/zabbix-emc...t_state.py#L87) returned 1. Check that you have zabbix-sender package installed correctly.
    Markku
    • bab
      • Aug 2020
      • 194
      Markku
      zabbiz_server ip = 172.2.20.20
      Yes . I have installed zabbix_sender on zabbix-server
      Also I set ServerActive=172.2.20.20 in /etc/zabbix/zabbix_agent2.conf
      and As I am using zabbix_agent2 so edit script in line 89 to config_path = "/etc/zabbix/zabbix_agent2.conf"
      Unfortunatelt It returns 1 another
      • Markku
        • Sep 2018
        • 1784
        https://www.zabbix.com/documentation.../zabbix_sender says that "If data sending failed, the exit status is 1."
        Check the Zabbix server logs, and if needed, comment out the os.remove() call in line 98, check the resulted file and run zabbix_sender manually with that data to find out what is wrong with your configuration. For example, do you have the matching host configured in Zabbix.
        Markku
        • bab
          • Aug 2020
          • 194
          Markku
          When I run that script it does not write anything in zabbix_server.log
          I comment line 98 so it create a log with the name bakunity_1653235554.tmp in /tmp that contains all information that we need for unity device such as battery , ssd disk , .......
          I am really confuse what is the issue
          • Markku
            • Sep 2018
            • 1784
            What is the error you get from zabbix_sender when you try to send the same bakunity* data file with the same arguments as the script uses?
            Markku
            • bab
              • Aug 2020
              • 194
              Markku
              Would you say what syntax I should use for that ?
              • Markku
                • Sep 2018
                • 1784
                Line 97 says
                [sender_command, "-vv", "-c", config_path, "-s", storage_name, "-T", "-i", temp_file]
                so
                /usr/bin/zabbix_sender -vv -c /etc/zabbix/zabbix_agent2.conf -s bakunity -T -i /tmp/bakunity_1653235554.tmp
                (https://www.zabbix.com/documentation.../zabbix_sender)
                Markku
                • bab
                  • Aug 2020
                  • 194
                  Line 97 says
                  so
                  Markku
                  That is strange , it shows :
                  zabbix_sender [207041]: ./zabbix_agent2.d/plugins.d: [2] No such file or directory
                  Also I have follow path :
                  [root@z6 externalscripts]# ll /etc/zabbix/zabbix_agent2.d/plugins.d/
                  total 44
                  -rw-r--r--. 1 root root 1591 May 3 12:00 ceph.conf
                  -rw-r--r--. 1 root root 1959 May 3 12:00 docker.conf
                  -rw-r--r--. 1 root root 1113 May 3 12:00 memcached.conf
                  -rw-r--r--. 1 root root 592 May 3 12:00 modbus.conf
                  -rw-r--r--. 1 root root 1112 May 3 12:00 mongodb.conf
                  -rw-r--r--. 1 root root 174 May 3 12:00 mqtt.conf
                  -rw-r--r--. 1 root root 2101 May 3 12:00 mysql.conf
                  -rw-r--r--. 1 root root 1700 May 3 12:00 oracle.conf
                  -rw-r--r--. 1 root root 2723 May 3 12:00 postgres.conf
                  -rw-r--r--. 1 root root 1174 May 3 12:00 redis.conf
                  -rw-r--r--. 1 root root 388 May 3 12:00 smart.conf
                  • Markku
                    • Sep 2018
                    • 1784
                    I have no experience in agent2, but https://www.zabbix.com/documentation...gent-2-plugins says about some changes in 6.x.
                    Try to edit the path in the Include statement in zabbix_agent2.conf to /etc/zabbix/zabbix_agent2.d/plugins.d (ie. add the full path to the plugins config directory instead of the relative path).
                    Markku
                    • dslauter
                      • Jun 2022
                      Hi bab I ran into the same issue, the way to fix it is to comment out the include in the bottom of the agent2 config file.
                      Include=./zabbix_agent2.d/plugins.d/*.conf
                      Alternatively you could edit that line to contain the full path to the plugins.d conf file.
