The zabbix server does not start
  • barbieri
    • May 2022
    The zabbix server does not start, I do not understand what error is causing this.
    sending my log file:
    57591:20220523:092612.542 Starting Zabbix Server. Zabbix 6.0.4 (revision 3d787ff402e).
    57591:20220523:092612.543 ****** Enabled features ******
    57591:20220523:092612.543 SNMP monitoring: YES
    57591:20220523:092612.543 IPMI monitoring: YES
    57591:20220523:092612.543 Web monitoring: YES
    57591:20220523:092612.543 VMware monitoring: YES
    57591:20220523:092612.543 SMTP authentication: YES
    57591:20220523:092612.543 ODBC: YES
    57591:20220523:092612.543 SSH support: YES
    57591:20220523:092612.543 IPv6 support: YES
    57591:20220523:092612.543 TLS support: YES
    57591:20220523:092612.543 ******************************
    57591:20220523:092612.543 using configuration file: /etc/zabbix/zabbix_server.conf
    57591:20220523:092612.562 current database version (mandatory/optional): 06000000/06000000
    57591:20220523:092612.562 required mandatory version: 06000000
    57592:20220523:092612.570 starting HA manager
    57592:20220523:092612.584 HA manager started in active mode
    57591:20220523:092612.585 server #0 started [main process]
    57593:20220523:092612.586 server Home started [service manager #1]
    57594:20220523:092612.586 server Forum started [configuration syncer #1]
    57594:20220523:092613.208 __mem_malloc: skipped 0 asked 72 skip_min 18446744073709551615 skip_max 0
    57594:20220523:092613.208 [file:dbconfig.c,line:89] __zbx_mem_malloc(): out of memory (requested 72 bytes)
    57594:20220523:092613.208 [file:dbconfig.c,line:89] __zbx_mem_malloc(): please increase CacheSize configuration parameter
    57594:20220523:092613.208 === memory statistics for configuration cache ===
    57594:20220523:092613.208 free chunks of size 24 bytes: 38
    57594:20220523:092613.208 free chunks of size 40 bytes: 3
    57594:20220523:092613.208 free chunks of size 64 bytes: 2
    57594:20220523:092613.208 min chunk size: 24 bytes
    57594:20220523:092613.208 max chunk size: 64 bytes
    57594:20220523:092613.208 memory of total size 28652224 bytes fragmented into 306365 chunks
    57594:20220523:092613.208 of those, 1160 bytes are in 43 free chunks
    57594:20220523:092613.208 of those, 28651064 bytes are in 306322 used chunks
    57594:20220523:092613.208 of those, 4901824 bytes are used by allocation overhead
    57594:20220523:092613.208 ================================
    57594:20220523:092613.208 === Backtrace: ===
    57594:20220523:092613.209 15: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_backtrace+0x52) [0x5650a874d46d]
    57594:20220523:092613.209 14: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](__zbx_mem_malloc+0x184) [0x5650a8747e7e]
    57594:20220523:092613.209 13: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1f30be) [0x5650a86c80be]
    57594:20220523:092613.209 12: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert_ext+0x133) [0x5650a8753f59]
    57594:20220523:092613.209 11: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_hashset_insert+0x31) [0x5650a8753e24]
    57594:20220523:092613.209 10: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCfind_id+0xb4) [0x5650a86c89e1]
    57594:20220523:092613.209 9: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x1fe669) [0x5650a86d3669]
    57594:20220523:092613.209 8: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](DCsync_configuration+0xf7c) [0x5650a86d847e]
    57594:20220523:092613.209 7: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](dbconfig_thread+0x149) [0x5650a8552866]
    57594:20220523:092613.209 6: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](zbx_thread_start+0x3b) [0x5650a875eb64]
    57594:20220523:092613.209 5: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](+0x6986f) [0x5650a853e86f]
    57594:20220523:092613.209 4: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](MAIN_ZABBIX_ENTRY+0x87c) [0x5650a853fb6c]
    57594:20220523:092613.209 3: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](daemon_start+0x3ca) [0x5650a874cf90]
    57594:20220523:092613.209 2: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](main+0x34d) [0x5650a853dee2]
    57594:20220523:092613.209 1: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf3) [0x7f4c20260083]
    57594:20220523:092613.209 0: /usr/sbin/zabbix_server: configuration syncer [syncing configuration](_start+0x2e) [0x5650a853cb4e]
    57591:20220523:092613.213 One child process died (PID:57594,exitcode/signal:1). Exiting ...
    57592:20220523:092613.213 HA manager has been paused
    57592:20220523:092613.240 HA manager has been stopped
    57591:20220523:092613.242 Zabbix Server stopped. Zabbix 6.0.4 (revision 3d787ff402e).
    • 4996
    Copy-paste here is so easy to do.. but you should also read it..
    There's suggestion what you should do...
    • barbieri
      barbieri commented
      Thank you very much, the problem has been fixed.
      I really hadn't read this before.
