Zabbix proxy monitoring
  • Adriano Trindade
    • May 2022
    • 19
    Hello!
    I have an environment with a lot of Zabbix proxies registered. Each customer have his own Zabbix Proxy.
    My problem is, when a proxy stops sending data to Zabbix Server, I want to receive an alarm because that proxy became inactive.
    There's a way to do that? I have searched and found nothing. I don't want to have to create manually one monitoring item for each proxy.
    Thanks in advance!
    • 4949
    https://www.zabbix.com/documentation...types/internal
    zabbix[proxy,<name>,<param>]
    Information about Zabbix proxy. Integer. name: proxy name
    Valid values for param are:
    lastaccess - timestamp of last heart beat message received from proxy
    delay - how long collected values are unsent, calculated as "proxy delay" (difference between the current proxy time and the timestamp of the oldest unsent value on proxy) + ("current server time" - "proxy lastaccess")
    Example:
    => zabbix[proxy,"Germany",lastaccess]
    fuzzytime() function can be used to check availability of proxies.
    This item is always processed by Zabbix server regardless of host location (on server or proxy).
    • Adriano Trindade
      • May 2022
      • 19
      Hello!
      As I understood, I have to create an item for each proxy anyway. But at least I can monitor it and take proper action.
      Many thanks for pointing me out, I can go forward from now on.
      • Adriano Trindade
        • May 2022
        • 19
        Another question hit me.
        Is there a way I can list registered proxies on Zabbix by name? This way I could make a discovery rule with automatic creation/removal of proxy monitoring items.
        Network discovery in this case doesn´t work, because each proxy isn't accessible from external networks. I need to query Zabbix configuration.
        Thanks in advance!
          • 4949
          API calls.https://www.zabbix.com/documentation...e/proxy/object
          • Adriano Trindade
            • May 2022
            • 19
            Thanks, looks like what I need. Will try tomorrow.
