Issue bad PostgreSQL version
  • Clayzes
    • May 2022
    • 29
    I tried to setup Zabbix using container following : https://www.zabbix.com/documentation...ion/containers (with postgre / nginx / snmp trap)
    But on the web interface , in "system information" I have the error: Maximum required PostgreSQL database version is 13.x.
    It's normal , the latest postgreSQL version is 14.3.
    Is it just a warning or it can really cause troubleshoot ?
    If it can cause troubleshoot , do you have any idea how to fix it ?
    Thank you
    • 4996
    What version you are trying to install? 13.x is max for 5.4... maybe you should try to install 6.0?
    • Clayzes
      • May 2022
      • 29
      hello ,
      I'm trying to install 6.0 following the link below https://www.zabbix.com/documentation...ion/containers
