Agent not running on Mac M1
  • Clayzes
    • May 2022
    • 29
    I tried to install Zabbix agent on macOS Monterey 12.3 with M1 processor
    I downloaded this agent : https://www.zabbix.com/download_agen...cy=0#tab:40LTS
    When I do : "sudo launchctl load /Library/LaunchDaemons/com.zabbix.zabbix_agentd.plist." to launch the agent
    Then : "ps aux | grep zabbix_agentd" to check if agent is running , I got : "myhostname 14372 0.0 0.0 408636560 1728 s000 S+ 10:49AM 0:00.00 grep zabbix_agentd"
    So the agent is not running ,
    Can someone already successed to make the agent running on M1 ?
    Thank you
  • Clayzes
    • May 2022
    • 29
    UP
    Is it possible to monitor system with arm architecture ?
    if it's not possible using zabbix agent , can we use snmp ?
    • tim.mooney
      • Dec 2012
      • 1432
      After you've tried to launch it, what messages are there in the zabbix_agetnd.log file? That may provide a better clue about what the problem is. My guess is that it's architecture-related, but that's just a guess.
      Do you have the capability to compile the agent yourself, from source code?
