Zabbix_server and zabbix_agent doesn't start automatically after install from source
  • Angel115
    • Jun 2022
    Hi There,
    I just install Zabbix from the source and neither of the server (zabbix_server) or agent (zabbix_agent) are starting automatically when I reboot.
    I've seen some people managing server using systemd.
    But in my case the zabbix_server.service doesn't exist. Should I create it manually or is there a way to create this service automatically?
    At the moment I have to run zabbix_server and zabbix_agent binary manually after each reboot.
    Thanks for your time,
    Angel
  • Answer selected by Angel115 at 07-06-2022, 11:44.
    Angel115
    • Jun 2022
    Thanks for your hint.
    I didn't find the doc for that on Zabbix Documentation site, but I find it here:
    Create a Service File for Zabbix
    If that can help some one else.
    Thanks for your help
    • Atsushi
      • Aug 2013
      • 2028
      If you installed from source, you will need to create the configuration file for systemd, log rotation settings, etc. yourself. Please refer to the setting file included in the package to set according to the OS you are using.
      • Angel115
        • Jun 2022
