Agent.Version Problem
  • d.roeper
    • Feb 2022
    • 17
    Migration from 5.0.x to 6.0.5 with Postgresql 13 and Timescale.
    Everything looks very good in itself. Data is saved and I can view the history of the data.
    But apparently not from all.
    Example:
    agent.version (Linux Agent but also Windows Agent)
    I see in the log of the agent (DebugLevel=4) that the request comes. No matter if automatically because of interval or manually via Test/Execute Now I see the entry in the log. But under Latest data the query does not appear. Interval is set to 1h and Latest data is set to Last Check e.g. 24h and more.
    But if I adjust the agent version (upgrade from 5 to 6) then it seems to show once the data also under Latest data.
    I have this problem on a migrated Zabbix server as well as on a freshly installed one.
    Is this intentional to save data? Or am I using Latest data incorrectly?
  • Markku
    • Sep 2018
    • 1784
    See the item configuration and Preprosessing page: most probably there is a step that discards duplicates, to save space in the database.
    Markku
    • d.roeper
      • Feb 2022
      • 17
      oh yes in the postprocessing it was then to be found. Here all the same values were deleted by the 1d value.
      If I now retrieve my item every 1h, it can take up to 25h before I see something again in the lates data.
      thanks a lot
