I'm trying to monitor a log file.
The host through which I access it is a "Cluster Access Point". Which means I have an agent installed with this configuration:
And the host, in the Zabbix GUI, is named WindowsClusterAccessPoint.
So no possibilities to use the builtin logfile monitor of the agent.
So I'm trying this, in powershell:
count the number of occurences of a string in a file.
From the CMD, directly on the machine, I can achieve it like this:
I can also make it work properly using a more complex pattern:
Using this with zabbix_get, it works:
BUT if I try this with a more complex pattern, I get this:
I have tried using a variable, with no more success.
I am running out of ideas.
My file looks like this:
if anyone had an idea, I'd gladly take it.
Hostname=WindowsClusterNode
C:\Users\me>powershell -Command "$f=Select-String -path d:\jbw\liste.txt -pattern 301 -allmatches; $f.count" 1658
C:\Users\me>powershell -Command "$f=Select-String -path d:\jbw\liste.txt -pattern "301, party" -allmatches; $f.count 1658
[root@ZBXSRVR]# /opt/zabxagent/bin/zabbix_get -s ZBXHOST -k system.run["powershell.exe -Command \"\$f=Select-String -path d:\jbw\liste.txt -Pattern 301 -AllMatches; \$f.count\""] 1658
[root@ZBXSRVR]# /opt/zabxagent/bin/zabbix_get -s ZBXHOST -k system.run["powershell.exe -Command \"\$f=Select-String -path d:\jbw\liste.txt -Pattern \"301, Called party identification not known\" -AllMatches; \$f.count\""] ZBX_NOTSUPPORTED
[root@ZBXSRVR]# pattern="301, Called party identification not known"
[root@ZBXSRVR]# /opt/zabxagent/bin/zabbix_get -s ZBXHOST -k system.run["powershell.exe -Command \"\$f=Select-String -path d:\jbw\liste.txt -Pattern ${pattern} -AllMatches; \$f.count\""]
ZBX_NOTSUPPORTED
[root@ZBXSRVR]# /opt/zabxagent/bin/zabbix_get -s ZBXHOST -k system.run["powershell.exe -Command \"\$f=Select-String -path d:\jbw\liste.txt -Pattern \"${pattern}\" -AllMatches; \$f.count\""]
ZBX_NOTSUPPORTED
random line 301, Called party identification not known 301, Called party identification not known another random line yet another random line another random line 301, Called party identification not known
