guest Failed login
  • Temnahvezdna
    • Jun 2022
    guest Failed login
    on one of my instalation, user Guest is trying to login to zabbix. I dont know what is the reason of that situation. Guest account is in on disable users, so when i change it to another group i have a lot of rows (in Audit log) with information "Guest Login". Above is a screen of Audit Log, ip adresses belong to LoadBalancers.
    What device/service/app is using guest account and login to zabbix? Where I should looking for a source of a this problem?
    Best Regards
  • PhYrE
    • May 2014
    Are you using the docker installation which is set up to do a healthcheck every 10 seconds, each one showing as a failed guest attempt? Yes I think it's silly that this audit logs like that, and more importantly that there's not a dedicated page which checks health but doesn't trigger any error. Disable the healthcheck and you'll not get these.
    • db100
      • Feb 2023
      • 62
      i am facing a similar issue... any workaround ?
      • santosra02
        • May 2023
        • 21
        Please check: https://support.zabbix.com/browse/ZBX-20401
        The fix suggested is: "You can disable suggested curl check and use port check only, or disable healthcheck completely. Everything depends on your infrastructure requirements."
