How add several hosts to zabbix by IP
  • mixmox
    • Apr 2020
    • 54
    hello.
    its possible to add A host into zabbix server by Zabbix > configuration > add host
    i have 100 hosts which identify by IP and they are from different range. i need to just PING them to check availability
    how can i add them ?
  • Markku
    • Sep 2018
    • 1788
    Hi, you can use Zabbix API, or some other tools (that use the API) like Zabbix-cli (https://github.com/unioslo/zabbix-cli).
    Or manually in the GUI: first create one host with correct template etc, and then use Clone button to save the next one by just changing the name+IP.
    Markku
