MS SQL Monitoring using Zabbix Agent
  • jasdeep!8
    • Mar 2022
    • 13
    I am trying to monitor MS SQL using the templates provide on zabbix share https://github.com/zabbix/community-...oft_SQL_Server.
    But after adding the templates and attaching them to the server I am getting unsupported item key for both of them.
    I am looking to monitor MS SQL DB and instances using the agent rather than ODBC.
    Any help would be much appreciated.
Name:	Screenshot 2022-06-13 123101.png
ID:	446087 Click image for larger version
  • oceanman
    • Jun 2022
    At first you should create a user for zabbix sql monitoring at each sql server
    My .ini files content like below
    nano /etc/odbc.ini
    [Zabbix180]
    Driver = ODBC Driver 17 for SQL Server
    Server = 10.0.0.180\\\Zabbix180,1433
    [Zabbix144]
    Server = 192.168.5.144\\\Zabbix144,1433
    [Zabbix40]
    Server = 10.0.0.40\\\Zabbix40,1433
    [Zabbix70]
    Server = 10.0.0.70\\\Zabbix70,1433
    [Zabbix60]
    Server = 10.0.0.60\\\Zabbix60,1433
    nano /etc/odbcinst.ini
    [ODBC Driver 18 for SQL Server]
    Description=Microsoft ODBC Driver 18 for SQL Server
    Driver=/opt/microsoft/msodbcsql18/lib64/libmsodbcsql-18.0.so.1.1
    UsageCount=1
    [ODBC Driver 17 for SQL Server]
    Description=Microsoft ODBC Driver 17 for SQL Server
    Driver=/opt/microsoft/msodbcsql17/lib64/libmsodbcsql-17.9.so.1.1
    UsageCount=10
    you should connect to sql server with this command from zabbix server.
    # isql -v Zabbix60 'zbxmonitor' 'sqluserpassword'
    • jasdeep!8
      jasdeep!8 commented
      Thanks for your reply.
      I actually want to monitor the metrics using zabbix agent rather than ODBC since some of the servers in our production are still on ODBC drivers 13 and I guess there's no backwards compatibility that's why I am seeking to do it via the agent.
      If you have any idea for the same that'll be really helpful. i have attached the link from where I have downloaded those templates using agent but they don't provide better clarity. If you could take a look and provide insight I'll be really thankful.
  • studero
    • Aug 2023
    • 85
    Hi all,
    I have the same problem. And do not want to use ODBC. So do you have found a solution about the problem.
    Regards
    Olivier​
      • 5004
      Templates linked in first post, use windows performance counters to retrieve data... You probably need to enable those. Besides that, it mentions usage of powershell script to do the discovery of DB-s and instances. But that script seems to be missing from git... I suppose it was meant to be installed and defined as UserParameter, that's why topic starter has those "unsupported key" notifications there... no UserParameters defined.
