zabbix 6.0 jmx problem
  • Harso
    • Jun 2022
    Hi to all ,
    I've problem with all jmx interface on my zabbix. When i manually run "test item" I had response but still status of all jmx interface is still unknown .
    In Jmx java gateway log everything look fine
    [FONT=monospace][COLOR=#000000]2022-06-15 08:43:23.543 [pool-2-thread-3] DEBUG com.zabbix.gateway.SocketProcessor - starting to process incoming connection [/COLOR]
    2022-06-15 08:43:24.047 [pool-2-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading Zabbix protocol header
    2022-06-15 08:43:24.047 [pool-2-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading 8 bytes of data length
    2022-06-15 08:43:24.048 [pool-2-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - reading 161 bytes of request data
    2022-06-15 08:43:24.048 [pool-2-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - received the following data in request: {"request":"java gateway jmx","jmx_endpoint":"service:jmx:rmi:///jndi/rmi://host:9005/jmxrmi","ke
    ys":["jmx["Catalina:type=Server",serverInfo]"]}
    2022-06-15 08:43:24.132 [pool-2-thread-3] DEBUG com.zabbix.gateway.SocketProcessor - RMI SSL hint cache cleanup is scheduled on 1655299759942, now is: 1655275404132
    2022-06-15 08:43:24.132 [pool-2-thread-3] DEBUG com.zabbix.gateway.SocketProcessor - dispatched request to class com.zabbix.gateway.JMXItemChecker
    2022-06-15 08:43:24.133 [pool-2-thread-3] DEBUG c.z.g.ZabbixJMXConnectorFactory - connecting to JMX agent at 'service:jmx:rmi:///jndi/rmi://host:9005/jmxrmi'
    2022-06-15 08:43:26.369 [pool-2-thread-3] DEBUG com.zabbix.gateway.JMXItemChecker - using RMI SSL for /jndi/rmi://host:9005/jmxrmi: false
    2022-06-15 08:43:26.370 [pool-2-thread-3] DEBUG com.zabbix.gateway.ItemChecker - getting value for item 'jmx["Catalina:type=Server",serverInfo]'
    2022-06-15 08:43:26.417 [pool-2-thread-3] DEBUG com.zabbix.gateway.ItemChecker - received value 'Apache Tomcat/7.0.108' for item 'jmx["Catalina:type=Server",serverInfo]'
    2022-06-15 08:43:26.418 [pool-2-thread-3] DEBUG c.z.gateway.BinaryProtocolSpeaker - sending the following data in response: {"data":[{"value":"Apache Tomcat\/7.0.108"}],"response":"success"}
    2022-06-15 08:43:26.419 [pool-2-thread-3] DEBUG com.zabbix.gateway.SocketProcessor - finished processing incoming connection[/FONT]
    I've zabbix server on centos 8
    rpm -qa |grep zabbix
    zabbix-web-6.0.5-1.el8.noarch
    zabbix-web-deps-6.0.5-1.el8.noarch
    zabbix-agent-6.0.5-1.el8.x86_64
    zabbix-get-6.0.5-1.el8.x86_64
    zabbix-release-6.0-1.el8.noarch
    zabbix-web-pgsql-6.0.5-1.el8.noarch
    zabbix-apache-conf-6.0.5-1.el8.noarch
    zabbix-sql-scripts-6.0.5-1.el8.noarch
    zabbix-selinux-policy-6.0.5-1.el8.x86_64
    zabbix-java-gateway-6.0.5-1.el8.x86_64
    zabbix-server-pgsql-6.0.5-1.el8.x86_64
    configuration zabbix server
    grep ^JavaGateway /etc/zabbix/zabbix_server.conf
    JavaGateway=127.0.0.1
    JavaGatewayPort=10052
    configuration java gateway
    grep ^[a-Z] /etc/zabbix/zabbix_java_gateway.conf
    LISTEN_IP="127.0.0.1"
    LISTEN_PORT=10052
    PID_FILE="/var/run/zabbix/zabbix_java_gateway.pid"
    START_POLLERS=5
    Before i had zabbix 3.0 and everything with jmx was ok.
    Do someone know where is problem?
    Thnx
  • sridhar43021
    • Oct 2022
    Did you manage to fix this? I'm also facing the same issue. My Zabbix version is 6.2.3.
