Issies with changing auth/priv to existing host
  • Sagimor
    • Jun 2022
    Hello everyone,
    So we have been using Zabbix for years now with no issues at all until today.
    We have updated the SNMPv3 priv/auth in our devices (Cisco Nexus switches) and since that moment, we are getting at error that the Zabbix fails to authenticate.
    It seems that the Zabbix will keep using the old priv/auth for all the hosts despite we have updated all the hosts hours before..
    We are using macros that holds the passwords, but even when trying to set the new credentials without macro (clear test string) it still failed to authenticate and kept using old creds.
    We did not (yet) try to complete remove the host and re-create it with the new creds, as this will delete all previous data.
    We also did not try (yet) to restart the server/service, first we must know if there is a more simple solution.
    Zabbix version (a bit old!) is 5.0.11
    Any suggestions/ideas will be appreciated.
    Thanks a lot.
    Sagi.
  • Hamardaban
    • May 2019
    • 2714
    Your version of zabbix does not support new encryption algorithms (by the way, what parameters are configured on the equipment?)
    for 5.0
    Authentication protocol Select authentication protocol - MD5 or SHA.
    Privacy protocol Select privacy protocol - DES or AES.
    for 6.0
    Authentication protocol Select authentication protocol - MD5, SHA1, SHA224, SHA256, SHA384 or SHA512.
    Privacy protocol Select privacy protocol - DES, AES128, AES192, AES256, AES192C (Cisco) or AES256C (Cisco)
    Update!
      • 5004
      Restart proxy/server (whichever is monitoring the devices) after change of snmp credentials. Otherwise it keeps using old ones.
      • Sagimor
        • Jun 2022
        Thanks guys,
        Hamardaban - We are using auth sha and priv aes. and it worked great, we just could not change the password.
        cyber - We though about it, restarting the service but it's big company with a lot of devices being monitored. so that's not at easy task to do - but if no other solution, we will.
          • 5004
          Its kind of a beaten path.. we just recently fixed a bunch of snmp templates, which had either typos or just wrong creds in them... it needs a restart after changing creds.. IIRC it caches stuff that is needed for snmpv3 communications (engineid-s, boottimes, creds) and when you change them, only way to re-cache it is restart...
          • Markku
            • Sep 2018
            • 1788
            There is the snmp_cache_reload command, doesn't it help?
            For server: https://www.zabbix.com/documentation...untime-control
            For proxy: https://www.zabbix.com/documentation...untime-control
            Markku
            • chrullrich
              • Jan 2013
              For the record: It does.
