Failed import of templates via API. Zabbix 6.0.5
  • eithor
    • May 2020
    • 50
    Hi all,
    I'm trying to import the standard yaml templates from Zabbix after upgrade to 6.0.5. Since the web gui requires very many clicks to import all the templates, I wanted to use the API.
    I've used the pyzabbix api (now in version 1.0, https://github.com/lukecyca/pyzabbix) for exporting templates in yaml or xml format. Using the pyzabbix api for import gives no error messages, a "True" result code fromt he API - but no changes visible in the web. Also, I cannot see anything in the zabbix server logs (at level 3), or zabbix audit-logs. I also tried to export an existing template to xml, change it, then re-import the xml, same result: no errors but also no changes.
    I'm calling the pyzabbix like the below code after zapi login, taken from zabbix-gnomes ztmplimport.py and changed to py3 and yaml (it seems that code blocks is not allowing python indents, sorry about that).
    Please advice how I can test this further. Anyone else seen the same thing?
    Thanks,
    Eirik
    for template in args.templates:
    Continue = True
    if Continue:
    try:
    # open file for reading
    with open(template,'r') as f:
    yamlfile = f.read()
    f.close()
    except:
    # If the file can't be opened, exit with error
    error = "Error: Something went wrong when trying to read the file" + template
    PrintError(error)
    Continue = False
    if Continue:
    try:
    # verify if the file is a valid YAML
    yparse = yaml.safe_load(yamlfile)
    except:
    # If the file isn't a valid YAML, exit with error
    error = "Error: YAML is not valid in " + template
    PrintError(error)
    Continue = False
    if Continue:
    try:
    # Everything looks good, let's try to import
    #result = zapi.configuration.Import(
    result = zapi.confimport( confformat="yaml", rules=rules, source=yamlfile)
    print(result)
    except ZabbixAPIException as e:
    print(e)
    # Something went wrong with the API call or import
    error = "Error: Something went wrong while importing " + \
    template + "\n" + str(e) + str(sys.exc_info()[1][0])
    PrintError(error)
    Continue = False
    if args.verbose:
    print(("Succesfully imported " + template))
    # And we're done...
  • Markku
    • Sep 2018
    • 1784
    What does the audit log say (Reports - Audit)?
    Markku
    • eithor
      • May 2020
      • 50
      The audit logs have nothing about items from the template. Just some repeated entries - every 1 or 2 minutes, still ongoing, with the same resource-id and description, different recordset hash, from the System user.
      Description: IPMI: CPU1 Temp, C
      item.tag[14503]: Updated
      item.tag[14503].tag: sensor => component
      item.tag[14503].value: temperature => environment
      item.tag[82900]: Updated
      item.tag[82900].tag: component => sensor
      item.tag[82900].value: environment => temperature
      Could it be that part of the last template import in web gui is going on in a loop?
      Eirik
