Locked out of UI with LDAP authentication
  • markfree
    • Apr 2019
    • 874
    I've managed to lock myself out of Zabbix 6 while configuring a new installment.
    I've configured LDAP login, then changed the default login type to it, but forgot to create a new user with admin privileges.
    After that, "Admin" account could not login anymore and I can't access Zabbix UI anymore.
    Any idea how to change back the default login to "internal"?
  • Answer selected by markfree at 04-07-2022, 02:36.
    markfree
    • Apr 2019
    • 874
    Great Markku !
    That did it.
    I've changed authentication_type from config table and now I'm able to login.
    mysql> update config set authentication_type=0;
    Query OK, 1 row affected (0.00 sec)
    mysql> select authentication_type from config limit 10;
    | authentication_type |
    | 0 |
    Thanks a lot.
    • Markku
      • Sep 2018
      • 1784
      Does this help you: https://www.zabbix.com/forum/zabbix-...ied#post244760
      Markku
      • markfree
        • Apr 2019
        • 874
        Great Markku !
        That did it.
        | 0 |
        Thanks a lot.
