zabbix_server (Zabbix) 6.0.6 + openssl 3.0.x + PSK + Ubuntu 22.04
  • cza
    • Jun 2022
    Hello to All,
    I have an issue with setting up PSK-based encryption between two Ubuntu 22.04 servers with openssl 3.0.2.
    The error is:
    2198:20220630:083740.155 failed to accept an incoming connection: from 10.100.10.103: TLS handshake set result code to 1: file ../ssl/t1_lib.c line 3220 func tls_choose_sigalg: error:0A000076:SSL routines::no suitable signature algorithm: TLS write fatal alert "handshake failure"
    2197:20220630:083740.155 failed to accept an incoming connection: from 10.100.10.103: unencrypted connections are not allowed
    Versions of zabbix server and zabbix agent are:
    zabbix_agentd (daemon) (Zabbix) 6.0.6
    Revision 3f7597e3ea3 27 June 2022, compilation time: Jun 27 2022 08:04:13
    Copyright (C) 2022 Zabbix SIA
    License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl.html>.
    This is free software: you are free to change and redistribute it according to
    the license. There is NO WARRANTY, to the extent permitted by law.
    This product includes software developed by the OpenSSL Project
    for use in the OpenSSL Toolkit (http://www.openssl.org/).
    Compiled with OpenSSL 3.0.2 15 Mar 2022
    Running with OpenSSL 3.0.2 15 Mar 2022
    Openssl version on both machines is:
    OpenSSL 3.0.2 15 Mar 2022 (Library: OpenSSL 3.0.2 15 Mar 2022)
    When I execute command from zabbix server to another Ubuntu 22.04:
    openssl s_client -connect some.server.com:10050 -psk_identity 'zabbix-example' -psk '<PSK-String>'
    This is what I get:
    CONNECTED(00000003)
    801BD3BD757F0000:error:0A000126:SSL routines:ssl3_read_n:unexpected eof while reading:../ssl/record/rec_layer_s3.c:308:
    no peer certificate available
    No client certificate CA names sent
    SSL handshake has read 0 bytes and written 443 bytes
    Verification: OK
    New, (NONE), Cipher is (NONE)
    Secure Renegotiation IS NOT supported
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    Early data was not sent
    Verify return code: 0 (ok)
    However if I execute the same command to server with older Ubuntu version (20.04,18.04,16.04), I'm getting this:
    CONNECTED(00000003)
    Server Temp Key: ECDH, prime256v1, 256 bits
    SSL handshake has read 351 bytes and written 965 bytes
    Verification: OK
    Reused, TLSv1.3, Cipher is TLS_CHACHA20_POLY1305_SHA256
    Compression: NONE
    Expansion: NONE
    No ALPN negotiated
    Post-Handshake New Session Ticket arrived:
    SSL-Session:
    Protocol : TLSv1.3
    Cipher : TLS_CHACHA20_POLY1305_SHA256
    Session-ID: C9198F1534C9E0696212AF5934164BAE7092033DE61816FB8 E5DC0CA0ADFEC2
    Session-ID-ctx:
    Resumption PSK: C9252DC6A9873D0679EFA8C27F58A5AF63C4E40986ED941B 33766FE3F7CF6
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    TLS session ticket lifetime hint: 304 (seconds)
    TLS session ticket:
    0000 - c3 74 0b 84 14 9d e6 12-53 0a 37 73 e9 8b 8e 0a .t......S.7s....
    0010 - e2 b4 3b 66 81 e9 93 ff-3c 7e 21 80 ec 27 cb 51 ..;f....<~!..'.Q
    Start Time: 1656571936
    Timeout : 304 (sec)
    Verify return code: 1 (unspecified certificate verification error)
    Extended master secret: no
    Max Early Data: 0
    read R BLOCK
    closed
    I tried to added this to zabbix-server config but it did not changed anything:
    TLSCipherPSK13=TLS_CHACHA20_POLY1305_SHA256:TLS_AE S_128_GCM_SHA256
    Does anyone knows what might be the issue here?
    Thank You in advance
  • Answer selected by cza at 02-11-2022, 16:48.
    cza
    • Jun 2022
    Hello All,
    There was no issue with Zabbix server, client or openssl.
    Issue is that filtering rules on router/firewall was somehow deforming TLS traffic between networks.
    If you have similar issue please use this command to diagnose if zabbix-agent establishes proper TLS connection:
    openssl s_client -connect agent_ip:10050 -psk_identity 'PSK' -psk 'some_psk'
    If you have "Cipher is (NONE)" response behind filewall and response like "Reused, TLSv1.3, Cipher is TLS_CHACHA20_POLY1305_SHA256" in the same network, then for sure it is network related issue.
    Bests.
    • cza
      • Jun 2022
      Hello All,
      Bests.
