Zabbix 6 host connection problems
  • Support IT
    • Jul 2022
    I get the following error about zabbix agent availability: ''Get value from agent failed: ZBX_TCP_READ() failed: [104] Connection reset by peer".
    Zabbix server version is 6.0.6 on a debian 11 and the agents are on windows 10 machines.
    I am also able to telnet from both sides on ports 10050,10051.
    SNMP agents lost too and i cant seem to understand why, so any help would be appreciated
  • Answer selected by Support IT at 14-07-2022, 09:26.
    vladimir_lv
    • May 2022
    • 240
    Hi!
    There are some reasons why you get such an error:
    1. Zabbix agent closes the connection because it comes from a host or IP address, not matching "Server=" parameter in zabbix_agentd.conf file.
    2. If you have used encryption, so check your TLS settings
    3. Some network device (firewall) between server and agent is disrupting communication.
    • vladimir_lv
      • May 2022
      • 240
      Hi!
      • Support IT
        • Jul 2022
        Thanks for your suggestions.
        It is my debian VM (on ESXi host) that was causing the problem (Zabbix runs on Debian OS). Although i have assigned a static ip address, there is a second one from dhcp even though i have only one network interface. Still haven't figured out where is coming from...
        Once i added this second ip to "Server=" parameter in zabbix_agentd.conf, agents began to show up.
