I can't see the graph
  • liuxh6
    • Nov 2006
    • 12
    hi,
    I install zabbix 1.1.3 ,it work ,I create graph ,but I can't see the graph,
    I have install the php-gd,the php info:
    gd
    GD Support enabled
    GD Version bundled (2.0.28 compatible)
    GIF Read Support enabled
    GIF Create Support enabled
    JPG Support enabled
    PNG Support enabled
    WBMP Support enabled
    XBM Support enabled
    Linux ibmsx15 2.4.21-4.ELsmp #1 SMP Fri Oct 3 17:52:56 EDT 2003 i686
    Build Date Nov 2 2006 16:08:38
    Configure Command './configure' '--prefix=/usr/local/php' '--with-apxs2=/usr/local/apache/bin/apxs' '--with-oci8=/home/oracle/product/10.2.0.1' '--with-gd' '--with-jpeg-dir=usr/local/lib' '--with-zlib-dir' '--with-png' '--with-freetype'
    Server API Apache 2.0 Handler
    Virtual Directory Support disabled
    Configuration File (php.ini) Path /usr/local/php/lib
    PHP API 20041225
    PHP Extension 20050922
    Zend Extension 220051025
    Debug Build no
    Thread Safety disabled
    Zend Memory Manager enabled
    IPv6 Support enabled
    Registered PHP Streams php, file, http, ftp, compress.zlib
    Registered Stream Socket Transports tcp, udp, unix, udg
    Registered Stream Filters string.rot13, string.toupper, string.tolower, string.strip_tags, convert.*, consumed, convert.iconv.*, zlib.*
    How can I solve it?
  • bibi23
    • Oct 2005
    • 64
    see post
    hi,
    i post update for this problem with oracle:
    • liuxh6
      • Nov 2006
      • 12
      thanks your help
      but it'not appear the graph yet,how can I do?
      • liuxh6
        • Nov 2006
        • 12
        thank you,I can see the graph,your patch is right
