Failed to start Zabbix Server
  • amazingwall
    • Jul 2022
    I want run zabbix but stuck with these errors.Please gave some troubleshoot ideas to ran it well.
    1-"systemctl status zabbix-server.service" and "journalctl -xe" both show the same error Failed to start Zabbix Server.I tried almost anything from the internet with no luck.
    2-When i run "systemctl restart zabbix-server zabbix-agent apache2" it tells to type initial commands. It throws below error.
    (Job for zabbix-server.service failed because the control process exited with error code.See "systemctl status zabbix-server.service" and "journalctl -xe" for details.)
    3-Also one more command "systemctl status php-fpm.service" output is like this one (Unit php-fpm.service could not be found.)
    Please tell if anything further needed.Thank you
  • Markku
    • Sep 2018
    • 1784
    What is your Linux distribution and version?
    What is your Zabbix server version?
    How did you install Zabbix?
    What does Zabbix server logs (/var/log/zabbix/zabbix_server.log) say?
    Markku
    • amazingwall
      • Jul 2022
      Previous error is resolved by reinstallation,but now i got 'Zabbix agent is not available" this error on zabbix dashboard.I checked all IP's.They seems OK to me.
