host interface ip/dns for snmp trap
  • nttscao
    • Jul 2022
    just set up snmp traps (Zabbix 5.2.0), everything is ok, but it looks like the host interface has to be IP address, dns does not work, when I use IP address, the traps show up in Zabbix, but will not show up after switch to dns, the log shows "unmatched trap received from" message, when I switch back to IP address, it works again, may be I missed some config settings?
  • nttscao
    • Jul 2022
    can anyone share experiences on setting up snmptraps? especially on choosing host interfaces - IP address vs DNS name,
    • dimir
      Zabbix developer
      • Apr 2011
      • 1080
      Are you sure the DNS name you set in the interface configuration form resolves to the IP that sends the traps to Zabbix?
      • nttscao
        • Jul 2022
        I have both ip and dns configured and switch between them, all other SNMP pulling are working correctly with either ip or dns, below loggings show snmptrapd is receiving traps (#1 and #3), but "unmatched trap" in logging (#2) when zabbix failed to process the trap with dns selected,
        Aug 16 18:57:14 zabbix2.test.dllstx09.us.to.gin.ntt.net snmptrapd[8785]: 2022-08-16 18:57:14 129.250.81.157(via UDP: [129.250.81.157]:33079->[204.2.140.14]:162) TRAP, SNMP v1, community public
        PowerNet-MIB::apc Enterprise Specific Trap (PowerNet-MIB::apcTestTrap) Uptime: 26 days, 22:08:52.80
        DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (232613280) 26 days, 22:08:52.80
        SNMPv2-MIB::snmpTrapOID.0 = OID: PowerNet-MIB::apcTestTrap
        Aug 16 18:57:15 zabbix2.test.dllstx09.us.to.gin.ntt.net zabbix_server[428]: unmatched trap received from "129.250.81.157": 18:57:14 2022/08/16 PDU INFO:
        transactionid 3186
        messageid 0
        receivedfrom UDP: [129.250.81.157]:33079->[204.2.140.14]:162
        community public
        requestid 0
        notificationtype TRAP
        errorindex 0
        errorstatus 0
        version 0
        VARBINDS:
        DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (232613280) 26 days, 22:08:52.80
        SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: PowerNet-MIB::apcTestTrap
        SNMP-COMMUNITY-MIB::snmpTrapAddress.0 type=64 value=IpAddress: 129.250.81.157
        SNMP-COMMUNITY-MIB::snmpTrapCommunity.0 type=4 value=STRING: "public"
        SNMPv2-MIB::snmpTrapEnterprise.0 type=6 value=OID: PowerNet-MIB::apc
        Aug 16 20:19:17 zabbix2.test.dllstx09.us.to.gin.ntt.net snmptrapd[8785]: 2022-08-16 20:19:17 129.250.81.157(via UDP: [129.250.81.157]:33960->[204.2.140.14]:162) TRAP, SNMP v1, community public
        PowerNet-MIB::apc Enterprise Specific Trap (PowerNet-MIB::apcTestTrap) Uptime: 26 days, 23:30:56.40
        DISMAN-EVENT-MIB::sysUpTimeInstance = Timeticks: (233105640) 26 days, 23:30:56.40
        thanks!
        • Alagie Jammeh
          • Aug 2022
          get value from agent failed cannot connect to ip 10050 4 interrupted system call
          • nttscao
            • Jul 2022
            I'd appreciate any one uses SNMPTRAP can share their experiences on using IP address vs DNS name,
            • Peter Franca
              • Aug 2018
              • 9
              Having the same issue. Zabbix only logging traps if I use ip instead of a dns interface.
              • doffy
                • Jan 2019
                Same situation experienced if in host SNMP interface used DNS name. Work fine with IP address.
                • ITOMDave
                  • Nov 2018
                  • 53
                  Hi all,
                  Although I don't have a fix for this (and I have the same problem), I *might* have a reason for it.....
                  The incoming trap doesn't have the DNS name (FQDN) of the host :
                  If you changed the SNMP host interface definition to "129.250.81.157" then there would be a match in Zabbix and it would work.
                  This of course would cause problems if the DNS name is actually a dynamic DNS service and the IP Address changes regularly.
                  I wonder, can snmptrapd be configured to translate source IP Addresses to FQDN's - i.e. do the equivalent of an nslookup on the receivedfrom IP address ? I'll go and have a look around.
                  Dave.
                  • Markku
                    • Sep 2018
                    • 1784
                    You can at least modify the trap receiver Perl script (https://git.zabbix.com/projects/ZBX/...ap_receiver.pl) to do a reverse lookup for the IP if you want.
                    Markku
