Cannot delete hosts "" because maintenance "exch" must contain at least one host...
  • leon.vinther
    • Jul 2022
    Upgrade from 5.0.25 to 6.2 and after my upgrade I decided to cleanup my maintenance jobs, so I deleted all of them to make new ones.
    After I deleted the jobs I can no longer delete hosts from "Maintenance"->"Hosts"
    All I get is the message in the topic.
    I have check the tables below and they are empty.
    select * from maintenances;
    Empty set (0.000 sec)
    select * from maintenances_groups;
    Anyone idea on how to correct this, so I can delete hosts again?
    Best Regards,
    Leon
  • vladimir_lv
    • May 2022
    • 240
    Did you mean Configuration->Hosts ?
    Check these hosts using the query:
     select * from maintenances_hosts;
    • leon.vinther
      • Jul 2022
      I used phpMyAdmin to run the selection and it returned an empty result.
      SELECT * FROM `maintenances_hosts`
      "MySQL returnerede ingen data (fx ingen rækker). (Forespørgsel tog 0.0003 sekunder.)"
      I looked through all of the maintenances tables and they are all empty.
      • vladimir_lv
        • May 2022
        • 240
        Use debug features of the frontend and you will see the queries when you try to delete the host.
        • vladimir_lv
          • May 2022
          • 240
          Check this:
          select maintenanceid, maintenance_status, maintenance_type, maintenance_from from hosts where hostid= YOUR_HOST_ID;
          and then clear these columns for discovered hosts.
          • leon.vinther
            • Jul 2022
            I get the following result:
